iPad 3 Block Moving Offset
Guest shared this problem 4 years ago
Solved
Hey guys, I am playing Hex on my iPad 3 and whenever I press and move a block ghe block jumps to the left by a certain amount. As a games developer and programmer myself, this looks like a problem with your touch input or perhaps not supporting my device's resolution. My iPad's screen resolution is 2048x1536. Hope you guys can fix this, although it is not a major problem.
Comments (1)
69
While the offset is a bit much (I am adjusting it), the offset is actually intended. This allows you to see what you are doing on touch devices. Without it, it's a worse game experience.
